It is currently Thu Aug 21, 2025 9:37 am
PostPosted: Mon Oct 28, 2013 9:13 am
Okay lads and ladies, I need help with coloration. I'm working on 2 cocobolo dreads and after re-sawing the wood for the backs I ended up with very different colors than when I started. Question: How to I get the 'orange-looking' cocobolo back to the 'brown/purple-looking' state from which it started?
Thanks in advance!!
Michael Anthony
"Life's short. Play guitar!"
PostPosted: Mon Oct 28, 2013 9:41 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
Have you sanded yet? The colors should match up after sanding. Cocobolo will oxidize over time, so the freshly opened up surface will always be lighter. If you sand the old oxidized surface it should lighten up to match the fresh surface.
Edit: oops, realizes I didn't really answer your question. What James and Todd said below.
These users thanked the author Goodin for the post: Michael Anthony (Mon Oct 28, 2013 12:30 pm)
First name: Ringo
Time and exposure to air will remove the purples.
These users thanked the author James Ringelspaugh for the post: Michael Anthony (Mon Oct 28, 2013 12:30 pm)
PostPosted: Mon Oct 28, 2013 12:39 pm
Just keep building the guitar; time will even-out the coloring for you...
These users thanked the author grumpy for the post: Michael Anthony (Mon Oct 28, 2013 1:51 pm)
PostPosted: Mon Oct 28, 2013 4:57 pm
First name: Eric
Last Name: Reams
City: Hudson
State: FL
Zip/Postal Code: 34667
+1 on the "it will do all the work". I have some I've used for fretboards that started out BRIGHT orange/red and are now a nice, even "brownish".
These users thanked the author emoney for the post: Michael Anthony (Tue Oct 29, 2013 9:13 am)
PostPosted: Tue Oct 29, 2013 12:15 am
Last Name: smith
City: hemet
State: ca
Zip/Postal Code: 92543
How long does it take to go brown and how dark does it get? Im thinking if the guitar is kept in a case it may never go brown. What do you think?
PostPosted: Tue Oct 29, 2013 9:20 am
I've built 4 cocobolo guitars, 2 turned brown, 2 stayed orange. My original question was aimed at whether anyone knows of an oxidizing agent that could speed the process as I have the patience of a 3 minute egg!! I wonder if delaying the finishing process is the key (as to allow oxygen to get to the wood). Any thoughts on that???
Regarding keeping the guitar in it's case.....if it has a finish, I doubt that in/out of the case would make much difference.....just my thinking on that one! Always open to any 'correction' of my thinking, so don't be shy if anyone thinks I'm loony-tunes!!
Michael Anthony
PostPosted: Tue Oct 29, 2013 9:38 am
First name: Gil
Last Name: Draper
City: Knoxville
State: Tennessee
I am no wood expert but I have built one instruments with coco. Like you said, some stay orange, some turn brown. The coco I used was brown when I got it, and stayed brown when I cut it. I think there is a alot of variability in the oxidation/coloration with this species. I think that since your wood was brown, then turned orange when you cut it, it will turn brown again. You could go ahead and build the guitar, get to final sanded, then let it sit out for awhile before finish. And/or use a thin finish, may help.
These users thanked the author Goodin for the post: Michael Anthony (Wed Oct 30, 2013 5:23 pm)
PostPosted: Tue Oct 29, 2013 10:14 am
If you resawed them, shouldn't they be a book match, both with freshly cut surfaces?
Regardless, by the time you join/scrape/sand they will look the same.
In the case that you want them to look the same before you build the guitar, you could just resurface the dark piece. (assuming you have enough thickness)
And forthly to answer your question, I don't know of anything to put on it to speed up the process. But, from what I've heard, some woods darken due to oxidation and some woods darken do to UV exposure.
These users thanked the author Pmaj7 for the post: Michael Anthony (Wed Oct 30, 2013 5:23 pm)
PostPosted: Tue Oct 29, 2013 4:36 pm
City: winnipeg
State: manitoba
Country: canada
I have found that mahogany darkens faster when exposed to sunlight.
Bob :ugeek:
These users thanked the author unkabob for the post: Michael Anthony (Wed Oct 30, 2013 5:24 pm)
Users browsing this forum: doncaparker and 5 guests
